Can someone help me regarding on this matter?
Thank you in advance.
Page 1 of 1
Changing Screen Saver on AB PanelView Plus 600 (MMI)
#2
Posted 14 August 2009 - 07:10 AM
See the attached technote for the information.
Attached File(s)
PV__screen_saver.doc (41K)
#3
Posted 14 August 2009 - 08:01 AM
ratcliffe_ic, on Aug 14 2009, 08:10 PM, said:
Hey ratcliffe_ic,
Thank you very much!
Btw, just wanna clarify regarding on the procedure. . . (place the name of the custom bitmap in the place of "oem.bmp")
Just this mean that the name only of the bitmap that I want to. How about its original bitmap file? I mean the graphic file (*.bmp).
Thanks again.
#4
Posted 14 August 2009 - 10:49 AM
Hey ratcliffe_ic,
Thanks again.
Let's say you have a bitmap called "nin_cals.bmp" just use this name in the bat file. Then you need to put both files onto your memory stick (nin_cals.bmp and autorun.bat). When you insert your memory stick the terminal changes to the windows CE environment and replaces the existing image with nin_cals.bmp. The document I attached explains how to revert to the original AB bitmap near the end of the document.
This post has been edited by ratcliffe_ic: 14 August 2009 - 10:51 AM
Share this topic:
Page 1 of 1
Sign In »
Register Now!
Help
Back to top
