BSL instruction and array tag
  • Please log in to reply
3 replies to this topic
#1 slcman
slcman
    Sparky
  • MrPLC Member
  • PipPipPip
  • 341 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 27 February 2007 - 10:10 PM
Hi,
I need to use data shift in my program. I want to use BSL instruction in a 1769-L32E plc. I'm not able to create a array tag. When I compile I alway have a error due to a array tag not created (picture). I did't found anything on "create a array tag" in help menu.
In my sample, array_1 is; type : Base Data type: DINT Scope: MainProgram Style: Decimal
Finally, I have another question: where is my first scan bit S:1/15 ???? I used these bit very often in my SLC pgm.
Thanks
Edited by slcman, 27 February 2007 - 10:34 PM.
SLCMAN
#2 Ken Roach
Ken Roach
    Propeller Head
  • MrPLC Member
  • PipPipPipPipPipPip
  • 2318 posts
Posted 27 February 2007 - 11:43 PM
Define your "array1" tag as a Boolean Array instead of a DINT. For the base data type, key in "BOOL[32]" or "BOOL[64]".
Arrays in ControlLogix are designated when you create the tag, and put the array dimension in square brackets. That's also how array elements are addressed in logic.
There are a small handful of Status flags that are implemented as pre-defined tags, including "S:FS", which is the First Scan bit. All other status information in the Logix family is accessed using Get System Variable (GSV) instructions.
#3 slcman
slcman
    Sparky
  • MrPLC Member
  • PipPipPip
  • 341 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 04 March 2007 - 01:56 PM
Thanks for your help. BOOL array doesn't work with BSL instruction, I must use a DINT array [1] for 32 bit shift register. I really appreciate S:FS bit....ist's hard to find on a first experience!
SLCMAN
#4 Contr_Conn
Contr_Conn
    Sparky
  • MrPLC Member
  • PipPipPip
  • 426 posts
  • Country:United States
    United States
Posted 04 March 2007 - 02:41 PM
In tag editor specify array_1 properties as DINT[1]
In BSL instruction specify array_1[0] to point to the first array word
