Flodis
Mitsubishi L02CPU-P Ethernet not responding
2 posts in this topic
We have an application using a Mitsubishi L02CPU-P with a built in ethernet module.
At one time the TCP/IP interface became irresponsive and a hard reset was required.
The device is configured for binary communication and works fine using a GOT therminal and also operates fine when queried from a GX Works application.
During debugging of a custom MELSEC application the TCP/IP interface stopped responding and could no longer be located using GX Works and the GOT terminal also lost contact.
The L02CPU-P continued running the control application, but could no longer be contacted. The only way to recover was using the L02CPU-P reset button.
I have heard developers being restrictive using the TCP/IP interface remotely over VPN and unstable connection due to the risk of hanging the device and not being able to recover without a personal visit to the device.
Any experience from L02CPU-P devices requiring hard reset to come "online" again? Or does it enter some default state due to some internal exception handling?
Edited by Flodis
I am starting to understand at least one MC-protocol or MELSEC "module" hast to be installed/activated on the PLC to enable communication.
When I query the PLC with the magic "Detect Now" button in the GX Works "Ethernet Configuration (Built-in Ethernet Port)"
In the "Host Station" column of the module list there is only one item "Module With No Profile Found" with Protocol UDP.
  • What Ethernet software module should I add to the PLC config for PLC to respond to MELSEC commands?
  • How do I write the added setting back to the PLC without affecting anything else?
Solution:
Enabling the MELSEC protocol
At lest this forum can be used as a cloud storage for documentation answering my own questions:
Dear Flodis, maybe you can find useful information in the MELSEC-L CPU Module User's Manual (Built-In Ethernet Function) - Page 38?
:-2
Edited by Flodis
Solution found
