MUSAK
About InverterRefresh
2 posts in this topic
Hı guys,
I will design new project  but I dont know that how can ı use  FB  at the
attachmend files
ı wanna send   speed  referances  for 23 motors with rs 485
I will not use   start and stop  function  for ınverters with modbus
ıt  will be doing   probably  only speeds of the motors
    1 )  Plc CP1EN40S DT1D
    2)   hmı : nb7 twb0
    3  ınverter s  :  V1000   VZABOP4BAA
how can ı use registers numbers of the ınverters so ı need simple program
thanks for  everythings
[767]InverterRefresh.zip
I don't know about your yagi drives but I control a Danfoss drive with a cp1l plc using function blocks using Modbus easy master to do basically the same as you want.
with the Danfoss drives you have the ability to control the drives via digital input and or fieldbus with the option for logic for one to override the other so you could use a relay output to start the drive and then use Modbus for the control word for speed reference.
http://forums.mrplc.com/index.php?/topic/33490-cp1l-modbus-coms-to-danfos-fc280-midi-drive-sample-program/
