Jim82
FX3GE - Analog configuration
7 posts in this topic
Hi Guys!
A simple question, im quite new to this so dont be to hard :)
I have a FX3GE plc and it has 2 analog inputs and 2 analog outputs built in, im using GXWorks2 as programming software.
How do i config those analog I/O ? I dont even know where to start :)
I want to use 1 analog output, set 0 - 10v depending on certain situations. But as i said, i dont know where to begin config this. :)
Br,
Jim
Hi Jim,
In the section 'Downloads' under tutorials I've placed a harware manual of type FX3GE model. See page 12/12 of this manual to find the D-words that need to be used with the on-board analogue in-outputs. (FX3GE hardwaremanual (English) Rev. F_April 2015)
Attached below a workshop that gives you some examples about configure the ananolgue signals. It is in Dutch however the screenshots and ladder logic speaks for it self.
Good luck and welcome to the Mitsubishi world.
Theo V.
FX3GE Hands-On Workshop GX-Works2 Analoog Part-Ladder en Struct GOT1455.pdf
1 person likes this
Thats great!
Thanks for the help, works like a charm!
Br,
Jim
Hi David,
See the attached picture with an example to set CH1 to 0-10Volt.
Did you check the manual in the tutorial section? See reply from february 22th 2016 above for the details and also I can recommend you to check out the workshop pdf file. Aldough it is in Dutch the pictures taken from GX-Works2 are in English. Succes!
Best regards,
Theo V.
Hi
 im quite new to gXworks 2  :)
How I can read the analog input in ladder logic.
Amit
