elhaimer
problems with DEVICENET !
I want to select and choose specefic datas that I want to supervize via DeviceNet protocol but in RSNETWORX it is not allowed to choose polled datas that I need to read or write because they are predefined by the constructer [One Input: motor data, One Output: control byte] . And by editing EDS file I can just modify the Input and the output but not to add an other one and MM300 does not support the Assebly Object so I can add as much as I need for my application. So the problem is how can I select the Inputs and outputs needed for my application (3 Inputs and 3 outputs). Thank you in advance for any insight and advice given ! Edited by elhaimer
This question would probably be best asked in the Rockwell section of the forum. Just saying... :)
Thank you for this information ! I post it here because isn`t just rockwell problem but GE too (Indeed it`s my problem) :) . Anyway, I`ll post it on rockwell forum. Edited by elhaimer
