Posted 19 Jul 2004 (edited) I have a S3D8 running a pneumatic pad printer. The original S3D8 died so I sourced a used replacement, I copied down the program step by step and entered the program in the replacement S3D8. All works OK except for probably one line of code. The ouptput 2 stays high, that is the light is on and the ram operates correctly. It should then go low and allow the ram to return for about 1½ second, then go high again. The output does go low but for only a very brief moment. How do I identify the line of code where the operation occurs and insert a delay. And what should the line say. File attached with program. / and \ denote rise and fall key. OMRON_PROGRAM_7_04.doc Edited 19 Jul 2004 by jasdewar Share this post Link to post Share on other sites
