Lee_H
Mitsubishi Q02H to Proface GP2600
11 posts in this topic
Hi all, I have a bit of problem that i am hoping someone can help me solve, currently i am fortunate enough to have a test rig/training setup comprising of; Mitsubishi Q312B rack Mitsubishi Q02HCPU Mitsubishi QJ71C24N RS232/422 card occupying slot 0 GP2600 HMI connected via the 422 terminals on QJ71C24N Self made connection lead with the configuration GP2600 PLC P7 - SG - SG P9 LINKED TO 10 P10 - RDA - SDA P11 - SDA - RDA P15 - SDB - RDB P16 - RDB - SDB P18 & 19 JOINED P20 & 21 JOINED I have downloaded all the available manuals from the Proface/Otasuke support site and have worked through them however i am still having difficulty in getting any communication between the GP2600 and the QJ71C24N and i am waiting (3 days now) for a response from Proface. The settings i have been trying to use are as follows; Device types GP2600 Mitsubishi-MELSEC Q CPU Extend SIO Type - NONE Communications settings COMMS RATE - 19200 DATA - 7 BITS STOP BIT - 2 PARITY - EVEN DATA FLOW - ER TYPE UNIT - 0 4 WIRE Which if my interpretation of the manuals is correct gives me the following switch settings for GX-Developer. Comms rate 19200 = 07h Switch 1 & 3 Transmission settings B0 Operation setting Independant(0),Linked(1) = 0 B1 Data bit 7(0),8(1) = 0 B2 Parity bit No(0),Yes(1) = 1 B3 Odd(0),Even(1) Parity = 1 B4 stop bit 1(0),2(1) = 1 B5 sum check code No(0),Yes(1) = 1 B6 Write during run No(0),Yes(1) = 0 B7 Setting modifications No(0),Yes(1) = 1 Above settings give BCh Combined gives 07BCh for switch 1 & 3 Switches 2 & 4 Communication protocol Default value of 0h Switch 5 - Station number Default value of 0h Despite all of the above i still recieve 'PLC Not Responding 02:FE' I have been struggling with this for several days now and assume i am missing something which once pointed out will be embarassing cheers and thanks Lee
your logic sounds right, at least i don't see problem with it but what are the values of the terminators you use and how are you using them?
Have only ever used a Proface once (with an Allen Bradley) and decided that I never wanted to use one again. Hardware was OK, but manuals and support were somewhat lacking to say the least. This is probably of no use, but I can't recall ever setting up a serial link with a Mitsubishi that used two Stop bits in the setup, it's always been one Stop bit...... but then again, I have yet to progress to the Q series.
this is what I've found:
Sorry for the delay in replying, thanks for all the pointers .... i think i see what i've done wrong, i've missed the termination resistors but i was buggered if i could see why it wasn't working and felt it had to be simple will try this Monday/Tuesday and let everyone know. Cheers and thanks,
OK then further to the previous response ... i have now fitted the resistors and still suffer from the same issues The GP26 still displays an 02:FE error with PLC not responding and the QJ71C24 card shows the following; RUN light = ON NEU light = ON (both channels) RD light = flashing SD light = OFF (never even blinks) I've re-checked all the settings, re-calculated the switch settings for GX-Developer, cleared all PLC & GP memories and started from scratch. Using GXDEV's system monitor i have confirmed the switch settings in the comms card and ensured no errors are reported. I have even altered it to 8 bits,no parity,1 stop bit,19200 and still nothing. To say i am stumped is something of an understatement, i am only using the GP screen because i have a few spare though i am beginning to wonder if i should dump it for a GOT but i refuse to give up. If anyone has any further pointers i'll gladly follow them ....... Thanks, Lee
Hi all, I think you should use GP230-IS11-O of Pro-face to connect GP and PLC. If you do not use, I am not sure they do not work. GP_PLC.bmp
i've never seen it, but that should be just a cable. check page 14 for example http://www.kwangwon.co.kr/customer/pds_fil...51221102311.pdf also what kind of cable you use? are you using proper pairs? wires going to SDA/SBD must be one twisted pair, wires going to RDA/RDB must be other......... Also read the note about jumping pins 9 and 10 on PG side
Hi, Firstly thanks to all who responded I have now got it successfully working and have posted a webpage up at http://www.lhalls.co.uk/gp26-mitsiq.htm Note there is nothing else on the site at the moment as it was all being worked upon but i thought i'd take a few screen shots and give a reasonable description for others to reference, i'll create a pdf file when i have time and upload here too. Briefly i got it working by setting it up as follows; On the Gp2600 side choose Mitsubishi MELSEC QnA(LINK) as your type and set-up the comms as 4 line, 19200, 7 data bits, even parity, 2 stop bits & DTR/ER control. On the PLC side set up the switches as SWITCH 1 & 3: 07FC SWITCH 2 & 4: 04 SWITCH 5: 0 The connecting cable should be twisted pairs but i managed to get it working with normal screened cable however ensure the resistors are correctly utilised and note that on my original cable i had pins 9 & 10 connected but on the working version they are not. P7 - SG - SG P10 - RDA - SDA P11 - SDA - RDA P15 - SDB - RDB P16 - RDB - SDB P18 & 19 JOINED P20 & 21 JOINED On the plc side connect SDA & SDB with a 330ohm resistor and also RDA & RDB. On the GP2600 side of the lead connect pins 10-RDA & 16-RDB together with a 330ohm resistor. Eventually if all is set-up correctly you will see both SD & RD lights flashing on CH2 of the QJ71 card. Hopefully the above helps some other poor sole struggling with it, one recommendation i would have is look into getting GX Configurator as this should simplify your settings calculations and never forget the importance of resistors ...... Regards, Lee
congratulation. sounds like proper termination did the trick (i see you have removed the connection between pins 9 and 10 on PG side)
yeah :( proper termination and a change in the hex switch settings, i had the termination on the plc side originally but took it off because it did not work, then posted here and re-added it. The key was the one on the hmi side and then a change in parameter settings. Thanks again for patience and pointers. Lee
