Rajeev Aswal
Hitachi Touch HMI with GE FANUC 90-30 CPU 374
4 posts in this topic
Hi, We are using Hitahi Touch Panel EHTP70 to communicate with GE FANUC 90-30 Series CPU 374+ . If any body did this application then plz let us know how to communicate , protocols used and cables Edited by Rajeev Aswal
It appears that your best choice might be a fieldbus like DeviceNet or Profibus. http://www.lighthouseplcs.com/hmi/index.html I didn't download any of the pdf files, but it doesn't look like they support SNPX protocol for serial communications.
If we use CMM321 then is it possible to communicate over MODBUS TCP/IP - with HITACHI Touch panel?
As long as the touch screen supports the Modbus TCP/IP protocol. It is fairly simple to set up the communication on the GE end. If you review the manual for the CMM321 chapter 4 has everything you would need to set up a stable commuication layout for your program.
