Posted 6 Aug 2006 need to disable the Devicenet controls on a 1398-DDM-009X-DN drive, to allow for independent operation (no network). Looks like it can be done but following questions. Can it be implemented using only Ultramaster or do I need to configure thru a Devicenet link? Manual description for parameter 285 indicates that this determines the fault response for a network failure. References DN Polled I/O set to Type 1 to disable the fault response. Cannot find DN Polled I/O Type in the param list. Any help? Thanks, bob Share this post Link to post Share on other sites
Posted 19 Sep 2014 Hi Bob did you get anywhere with the Devicenet drive? I'm in similar situation with exactly same drive. Regards ILia Share this post Link to post Share on other sites
