davidtorati
CQM1-cpu41
2 posts in this topic
Hello I have CQM1 cpu41 and I'm counting pulses from a sensor . I 'm getting 1256 mm for each four pulses, and i want to count meters. My questions are : 1. Can the DM be 32 bit register ? 2. Does the cpu-41 have floating point in order to calculate the meters count ? If not which PLC do I have to use in order to deal with floating point? Thanks David
The CQM1H has some floating point instructions but the CS/CJ series PLC's have a much better intruction set. CQM1 Programming Manual CS/CJ Programming Manual This file is a 13 MB download from Omron's site. Why do you need to count in meters? It appears (looking at your numbers) that single word BCD math will suffice for your mm calculation. Edited by IO_Rack
