Posted 12 Mar 2006 (edited) Browsing through the Omron FB library (supplied with CX-One) the other day I found this FB to setup a Modbus slave using a CS/CJ Serial comms unit. No more do we need to use protocol macros with supporting ladder code! It will support baud rates up to 115k ! I wonder if it will support using an external modbus/ethernet gateway to enable the PLC to be a modbus TCP slave? _SCx606_SetPortMODBUS_RTU.pdf Edited 12 Mar 2006 by Nibroc Share this post Link to post Share on other sites
Posted 27 Feb 2015 Hi Nibroc, GW-7473 is helpful for the data exchange Modbus to Ethernet/IP.You can check it out. http://www.icpdas-usa.com/gw_7473.html?r=Kaan Thank you, Share this post Link to post Share on other sites
Posted 27 Feb 2015 You do realize that post is nine years old?? I suspect he's solved his problem by now! 1 person likes this Share this post Link to post Share on other sites
