Posted 27 Dec 2005 Hello, I'm new on omron, could any one have basic instruction / reference menu about CPM1A-MAD02-CH. thanks Share this post Link to post Share on other sites
Posted 27 Dec 2005 You need the Programming Manual W353-E1-04 or newer. The Operation Manual W317-E1-3 or newer would be good to have handy too. You can go to the OMRON technical library and down load it. Most OMRON manuals are also in the technical down load section on this site or there is a link to them. Share this post Link to post Share on other sites
Posted 27 Dec 2005 (edited) First you have to write the range to the MAD. Look in the manual for the range you want. Use a first cycle flag to put the range with a MOV instruction to the MAD. If the MAD is right after the CPM1A. Then this will be channel 12, the next one will be 13 and so on. Then u can write a value to that channel from a DM with another MOV instruction. EDIT: Here is the program, you just have to edit it to your specifications. Edited 27 Dec 2005 by NOOBIE SvS Share this post Link to post Share on other sites
