Posted 14 Dec 2005 Hello everybody. I have an old OMRON C500 CPU11 with: ID219 -64 input card: addreses 000.00 till 003.15 OD213 -64 output card: addreses 004.00 till 007.15 NC103 position control unit Axis 1: NC103 position control unit Axis 2: NC103 position control unit Axis 3: ID213 -16 input card: OUT DC211 16 output card: every nc103 unit have 2chanels per16 bits but next inputs I mean 008.00.. doesn't exist in old program. (I think the program schould be completely) My problem is with all manuals I can't recognize where are the adresses for last 5 cards Enybody remember so old CPU model? Thanks in adwance for any help. Share this post Link to post Share on other sites
Posted 14 Dec 2005 Konrad, Per the W86-E1-1 manual, each NC103 will allocate 4 channels. So the first one will use channels 8-11, second channels 12-15, and third channels 16-19. That would make the ID213 channel 20 and the DC211 channel 21. Hope this helps. Share this post Link to post Share on other sites
Posted 15 Dec 2005 So if I good understand. the chanel 8 B0-15 Host PC -> position control unit data bus and chanel 10 B0-15 Host PC <- position control unit data bus example for axis 1 are not useded by working program? I checked chanel 9 and 11 is used and there is description for it in the axis manual. I miss the n and n+2 chanel seems be not used thanks for your help Share this post Link to post Share on other sites
Posted 15 Dec 2005 Yes, it sounds like you are understanding! I have not worked with this module, and the manual is a little confusing. If you have more detailed questions, we will need some other members to get involved. Good Luck! Share this post Link to post Share on other sites
Posted 15 Dec 2005 Thanks GTSUPPORT. I prepaired a list on EXCEL with all adresses for my configoration, is very usefull. On the NC103 are more bits not usedn not only in Chanel n and n+2, but that is I think not used especialy on my machine. But addreses are recognized. Now I have the next problem you can see on the new topic CNC error on NC103 Thanks for all help. Share this post Link to post Share on other sites
