Posted 30 Aug 2005 How to use FUNTION DECODER 7 SEGMENT in cpm2a, and how many output needed if i want to make a single digit 7 segment display Share this post Link to post Share on other sites
Posted 30 Aug 2005 The instruction will require 7 outputs, one for each segment of the display. The address is defined in the Destination word. The Digit Designator will define the number of digits to convert, and which digit(s) will be converted. Example: If you only want to convert one digit, and your value to convert is stored in DM100, and the display is wired to output channel 010: S = DM100 Di = #0000 D = 010 The manual (W353, Section 7-20-7) explains the details of which outputs activate the individual segments of the display. Hope this helps. gtsuport Share this post Link to post Share on other sites
