Posted 31 Jan 2003 i have plc 5/40 connected with a pc through dh + network ,now i want to see rslogix & rsview /data on a pc far distant from this ,where it is not possible to extend dh + ,what i have to do.i am having local lan. Share this post Link to post Share on other sites
Posted 31 Jan 2003 As you already have RSView and you are having a local area network, the simplest way to view you data remotely is to use the RSView Active Display System (ADS)(used to be called RAD). This leaves you existing RSView system as the server, your new PC on your LAN becomes the client, however you cannot edit existing graphics etc on the client, only on the server currently. The RAD server can only run on Windows 2000, NT or XP, not win 9x. This option is generally cheaper than a seperate RSView32 package running alongside the existing. Share this post Link to post Share on other sites
Posted 31 Jan 2003 It's not clear from the first post what software is on the existing PC - RSLogix 5 or RSView or both. However, installing ADS/RAD won't get you remote programming capability on the 5/40. You will no doubt have RSLinx (and a KT) on the existing PC. Upgrade that to the Gateway version and you will be able to access the DH+ from anywhere on the LAN. If you install the RSLogix and RSView activations on a network-shared drive, then you can install and run the s/w on multiple PC's...BUT....only one at a time. Share this post Link to post Share on other sites
Posted 3 Feb 2003 thanks for your suggestions. as you reqd i am having rs logix,view32 & rs linx oem all. now if i can see rs logix in remote pc & can do forcing etc function from that only. Share this post Link to post Share on other sites
