rfortier
API type CJ2m
3 posts in this topic
CX-Programmer 9.82, junior Licence.
i try to create a new Api and no CJ2M in Api type.
On plant, there's an CJ2M controller, i can acces by usb and go direct online, but Transfer from or to Api is gray. Need another version or connect otherway.
Thanks
Correct, the Junior version only does the small, brick-style PLCs.
I believe you can register at Omron's website and download a full trial version. It may be easier to contact your local Omron distributor.
IO is correct, Junior is essentially the same as the current "Lite" version. You can code your project in Junior and simulate/debug it. Most instructions are cross-compatible between CP and CJ. Use the trial version to transfer it when the time comes. Omron doesn't have the trial available for download anymore it seems - PM me if you want it.
