Posted 6 Jun 2023 Did anyone know Panasonic FP0R PLC is able to run multimer timer/counter at the same time? Maybe 4 - 6 timer, running for few hours. Thank you very much Share this post Link to post Share on other sites
Posted 6 Jun 2023 get the programming manual and check it out https://www3.panasonic.biz/ac/e/dl/manual/index.jsp?series_cd=1700 looks like FP0R has bunch of timers and can be used with different increments - 0.01s or 0.1s or 1s. using 1s base (TMY) you can have timer run for just over 9h. Share this post Link to post Share on other sites
Posted 7 Jun 2023 7 hours ago, panic mode said: get the programming manual and check it out https://www3.panasonic.biz/ac/e/dl/manual/index.jsp?series_cd=1700 looks like FP0R has bunch of timers and can be used with different increments - 0.01s or 0.1s or 1s. using 1s base (TMY) you can have timer run for just over 9h. Hi admin, I'm going to use FPWIN Pro 7 software for FP0R PLC. The picture is a sample for my program, I'm just worried all-timer and counter working at the same time will crash. I mean overlap. I have tried simulating, seems like it all working normally. ( 1H X 5 = 5H ) Share this post Link to post Share on other sites
Posted 7 Jun 2023 Why not use a preset of T#5h for 5 hours, why are you doing math? Timers are each stored separately based on the instance name you give it, so they will not overlap. Share this post Link to post Share on other sites
Posted 8 Jun 2023 5 hours ago, Crossbow said: Why not use a preset of T#5h for 5 hours, why are you doing math? Timers are each stored separately based on the instance name you give it, so they will not overlap. Hi Crossbow, i do understand math, the reason i use MUL_TIME_INT for Timer1 PT, is because the HMI(For Preset) i use, only able to key-in value in INT data type. So i key in 5 X T#1h = 5H, more easier to modify. So i can base on many different requirement to change the format in Minutes, Hour or Second. Let say the requirement in minutes, 300 X T#1m = 5h Share this post Link to post Share on other sites
Posted 8 Jun 2023 More familiar with Omron and Mitsubishi, they have commands to convert an int to a time, and they have different names than this. What threw me off is you are multiplying two constants, makes no sense. I would expect the int to be a variable if you are using an HMI. Share this post Link to post Share on other sites
