Jovel
Problem with Stepper Drive
10 posts in this topic
PLC : Mitsubishi FX5UJ-60MT/ES
Stepper Drive : TROY TR22-2
My problem is, When I Jog it, the Motor will have noise and vibrate(Example at video). I already ask my supplier and they test with their kit, my supplier says suspect the speed may not enough faster, so will have this noise. But when I use PLC to trigger it, still have the same problem. Even I increase the speed, the motor still rotates the same as the video.
i changed PLC to Omron  CP2E PLC, don't have this kind of issue.
Please help me,Thank you
WhatsApp Video 2023-05-25 at 12.53.32.mp4
Can you upload the gx3 project here?
What is the setting on the stepper driver(dip wsitches 1P/2P nd H/F?
What is the gear ratio?
How do you change the speed setting? Writing to data register Dn with HMI or GXW3?
Edited by glavanov
What is the microstep setting on the stepper driver?
The Speed setting Label at program is Jogspeed, Writing to Data Register (D) with HMI. The max i can key in in HMI is 600.
Sample Jog.gx3
Gear Ratio is 1:18
FX5UJ can only output Pulse and Direction unlike Fx5U CW/CCW...
What is the setting of dip switch 1P/2P on the stepper driver?
Edited by glavanov
1P is PULSE/SIGN
2P IS CW
I select 1P
Edited by Jovel
How do you change value of JogSpeed label since it's a local variable and no relation with any data register?
I assume you registered label in the hmi to some data register... You have to use that data register insted of JogSpeed label in the PLSV instruction.
Edited by glavanov
Don't Understand , the program I upload is an example, so I didn't assign anything. Ya, the Jogspeed, I got assigned D1000, HMI also D1000 when I tested it.
I see... Well, with this example I have nothing to add.
Sorry.
1 person likes this
It seems that you have bad program. Look at tags "Jogging" and "JogEND".
1 person likes this
