Posted 23 May 2023 Hello, Could someone explain to me the purpose of the STC(40) and CLC(41) instructions. If possible leave an example. Thanks. Share this post Link to post Share on other sites
Posted 23 May 2023 it is the same thing you do when adding numbers by hand using nothing but a pen and paper. for example adding 597 and 895 597 895 (+) ------ ???? so you start from the right side (least significant digit) and add those values 7+5 = 12. so you write down 2 (result is ___2)and remember to carry 1 (representing 10 actually) to the next position. then you are adding 9+9 but also must include value that was carried over (1) so sum here is really 9+9+1 = 19, and you write down 9 (result is __92), and carry 1 again. then you have 8+5 and since we still carry value from previous digit addition, it becomes 8+5+1=14. so you write down 4 (result now is _492) and you continue to to next position. since there is no more digits in the operands, we just have the carry (1). we write this down and result is 1492. if this was clear, you should have no problem adding numbers that have many more digits. same is with the computers - they can only handle limited chunks of data (based on instruction type and size of registers). so to break free from this limitation and be able to handle even very large values, carry value need to be considered. and programming manual has the nice example as well. before calculation one would reset the carry flag. setting flag is possible too but this is used less frequently 3 people like this Share this post Link to post Share on other sites
Posted 25 May 2023 Thanks for your answer. Very well explained. Share this post Link to post Share on other sites
