Festerr
Interrupt doesn't work
9 posts in this topic
Hi, guys!
Please, have a look at my test LD.
I've connected an AB encoder to X0, X1.
I want to count in D200 X0 rising edges, but it doesn't.
What's wrong?
Edited by Festerr
If you want to count pulses on X0, your address is looking at X1
There is an AB encoder with A -> X0 B-> X1 connected.
Also which PLC are you using if it's a modular version and you want the currect status of the input you shuld use DX0 instead of X0. or else you get the value from before the scan
It's chinese version of FX-1N
I don't know if there such function is implemented, but fast counters like C251 works fine.
I created this thread, because I'm not shure if  my LD is correct. I didn't work with interrupts before.
ok if it's an FX than you should use the special high speed counters.
You can use an AB counter aswell
Edited by Gambit
Ok, I know, how to use them, but they do some redundant and bad work. It will cause some excessive steps to overcome.
I've tried to avoid such.
