Posted 7 Mar 2023 (edited) I am trying to create a tag set between a NX102-9000 and a WAGO 750-352 using Ethernet/IP and for the life of me cannot figure out the I/O mapping between the two. If anyone has done this please help me! Only Info I have is that the DI is 2 Bytes and the DO is 1 Byte Edited 7 Mar 2023 by shiftyfatdwarf Share this post Link to post Share on other sites
Posted 7 Mar 2023 The WAGO 750-352 is just a coupler, the Input and Output sizes and layout will vary depending on the cards connected to the coupler. You should be able to see the data map with their configuration software from what I can read. Are you getting comms through and if so is the data just nonsensical? Share this post Link to post Share on other sites
