Paul@electrotech
NJ to ML1400 CIP Read
Omron NJ processor needed to Read data file from Allen Bradley MicroLogix 1400 PLC over EIP.
This method uses CPUCMMSend Function block to send a CIP message to the ML1400 to read 64 words of data from file register N32:0
Since our NJ PLC is using a CJ1W-EIP21 SIOU module for the EIP connection the RoutePath also needed to be determined.
Explicit CIPUCMM Send to Micrologix 1400 PLC to Read
Function Block Variable Name Variable Name Input Description
CIPUCMMSend
RoutePath RoutePathName 01/ When using an EtherNet/IP unit a connection is routed through the CPU backplane port (01)
    #10/ Unit number of EtherNet/IP unit + 10 (Unit number 00 + 10 gives #10)
    02/ When communcating through EtherNet/IP the communcation port route code is 02
    192.168.1.14 Target IP address of Micrologix 1400 PLC
TimeOut   UINT#20 Timeout time
ServiceCode ServCode 4B (Hex) PCCC Service Code - CreateSocket (75 dec)
      When configuring a MSG Command in RS Logix 500 as "unconnected MSG" and "Generic"
RqPath ReqPath: (Hex) the given Service code and Class ID are 4B (75 dec) and 67 (103 dec), respsectively.
  ClassID 67
  InstanceID  01 Should be set to 01 (1 dec)
  AttributeID 00 Do not use the Attribute ID
  isAttributeID FALSE
ServiceDat SrcMessage: (Hex) Command message to the Micrologix 1400
  SrcMessage[0] 07 Number of bytes in header is 7 (dec)
  SrcMessage[1] 01 Second byte of Vendor ID
  SrcMessage[2] 00 First byte of Vendor ID
  SrcMessage[3] 0d First byte of CIP Serial Number
  SrcMessage[4] 0c Second byte of CIP Serial Number
  SrcMessage[5] 0b Third byte of CIP Serial Number
  SrcMessage[6] 0b Last byte of CIP Serial Number
  SrcMessage[7] 0F Command Byte (15 dec) (Will be the same for read and write)
  SrcMessage[8] 00 Status Byte (Normally 0)
  SrcMessage[9] 4C LSB of TNS/TNSW
  SrcMessage[10] 00 MSB of TNS/TNSW
  SrcMessage[11] A2 Function byte (Protected Read with 3 address fields)
  SrcMessage[12] 82 Number of bytes to be Read (130 dec)
  SrcMessage[13] 20 The index number of file (32 dec) in our case N:32
  SrcMessage[14] 89 File data type (137 dec) is type integer, N
  SrcMessage[15] 00 Start element number (If it was 02 then would start at N32:2)
  SrcMessage[16] 00 Bit level address
Size SrcSize UINT#11 Size determines how many elements from the SrcMessage are sent (17 dec)
RespServiceDat RespDat:
  RespDat[0..10]   First 11 bytes in the response are the header we sent but will return a command byte of 4F
  RespDat[11..150]   The rest of the response data is the requested information from N32:00-N32:64 but is byte swapped
AryByteTo
In   RespDat[11] Takes the response data from after header as the input
Size   UINT#139 Size determines the number of elements input from RespDat. In our case RespDat[11..150]
Order   _eBYTE_ORDER#_LOW_HIGH Byte swaps each pair of bytes to form correct WORDs
OutVal ResDatWord   Outputs the read data in an array of WORDs
Are you needing help or just telling us how to do it?
Hi, Just telling you how we did it as there was very little information on the CIP message codes from ODVA and Rockwell.
Managed to back engineer from codes embedded in the Rockwell Message instruction.
Thanks for sharing. On a side note there are function blocks for the NJ/NX to read or write SLC and MicroLogix PLCs.
Thanks photovoltaic, We searched high and low for function blocks but couldn't find any - not even from Omron. Could you please direct me to their location.
