BADR
DEVICENET PROBLEM(CJ1w-DRM21)
5 posts in this topic
I'm not the most experienced programmer so please be patient with me how to eliminate left dot?????
-The Device Net card works as a slave card(CJ1w-DRM21)
-(MS/NS) LEDs are solid green
-Left dot= ON
-Right dot= OFF
master.png.93efd0403a1103a1c126c8254ddee
The documentation seems pretty clear.  You are using slave mode, so the master function is disabled.  Therefore, left dot is ON, and is working as documented.
Thank you, the communication problem, I scanned the network Via Cx-integrator: Device Network Issues on Palletized Assembly Line Omron CJ1W-DRM21 Device Net Slaves Error: Remote I/O Communication Error - Error Log (Hex) 0345 Detail: 0200.
Because the PV (Temperature) display problem, at the machine PLC level (Slave via CJ1w-DRM21) This is normal, But at the CIF-50-DNM Master level the value of PV (Temperature=0 °C).
I have an image insertion problem to explain better (Please your email to send the images).
I have zero experience with Cx-Integrator.  Maybe someone else can help you further.
