4w@rd
cutting position adjustment
I have motorized film adjustment and I was experiencing unstable cutting position during machine startup (acceleration) and stopping (deceleration). I have no problem during constant speed. Do you have any idea to fix the unstable cutting.
Maybe you should tell us what system you are using !!!
Until you can share some design details of your system there are too many variables to suggest a firm solution.
Most Film Cutting Systems I have worked with fall into one of two types.
Type A - Film is printed with a Registration Mark which the automation recognizes and the cut should be "X" mm from the registration mark.
Type B - Film is not printed or printed with ambiguous data and the cut simply every fixed distance {100 mm} as measured by the automation.
Without knowing this one variable we could propose the wrong answer to you.
