Posted 1 Feb 2023 Hello there, I have installed TIA Portal V16. There is a logic programming language called "Graph" in the siemens TIA Portal. This language is not installed by default in the TIA Portal. How to install that language Graph Language in TIA Portal ? Refer Images:- https://we.tl/t-BF2PtDcd7W Share this post Link to post Share on other sites
Posted 3 Feb 2023 Do you have Tia Portal 'Basic' or 'Professional'? Graph is not available in 'Basic'. Share this post Link to post Share on other sites
Posted 3 Feb 2023 Your probably know this… insert an FB under language when inserting see if graph shows in the drop down Share this post Link to post Share on other sites
Posted 26 Oct 2023 (edited) You can download S7 Graph from Siemens website. Edit: Where do you procure the current trial software for SIMATIC S7-GRAPH V5.6? - ID: 109748125 - Industry Support Siemens Edited 26 Oct 2023 by d4rkm4n add link Share this post Link to post Share on other sites
Posted 26 Oct 2023 You need to have a 1500 series PLC, to use GRAPH Share this post Link to post Share on other sites
