Posted 11 Jan 2023 I have been trying to connect to my nt21 hmi and I keep getting timeout error. I am able to connect to the plc with the same driver. So I know my cable is connected fine. I set the settings of the driver to match the hmi settings and still times out. Can someone please share the steps to take to send an application to this hmi? Share this post Link to post Share on other sites
Posted 11 Jan 2023 1 hour ago, GesipaMoc said: I am able to connect to the plc with the same driver. So I know my cable is connected fine. I'm not sure what you mean by driver. It's not the same cable as the PLC to PC or the PT to PLC. Here are the instructions for uploading and downloading. Also, appendix M will show the proper cable to use. The PT must be in Transmit Mode. You perform this manually by touching two corners of the screen. NT-Series Operation Manual (omron.eu) Share this post Link to post Share on other sites
Posted 11 Jan 2023 According to the manual I need to make my own cable? Is there an assembled cable? I am using CS1W-CIF31 Interface Unit to connect. Which is a usb to DB9 cable from omron. Quote 1 hour ago, IO_Rack said: You perform this manually by touching two corners of the screen. What do you mean by this? Share this post Link to post Share on other sites
Posted 11 Jan 2023 I think I figured out my issue. I need the XW2Z-S002 Cable to convert my interface unit for the NT Series. See page 21 in the manual. https://www.alliedelec.com/m/d/e7b2fde9bf2e3423eabdb87b07678924.pdf I will update the post once I receive the new cable. Share this post Link to post Share on other sites
