Posted 25 Nov 2022 Hi. what i've gathered, i need an EDS-file for the siemens s7-1200-system to be able to specify an ethernet connection in sysmac from the omron plc side to connect to the siemens ethernet/ip server. Anyone know where or how to get an EDS file for the siemens plc so i can import it into EIPprofiles in sysmac? Share this post Link to post Share on other sites
Posted 25 Nov 2022 Look like it is available if you are registered on their support website: https://support.industry.siemens.com/cs/document/109782315/ethernet-ip-adapter-connecting-third-party-control-systems-to-simatic-s7-controllers-via-ethernet-ip?dti=0&lc=en-HN Alternatively you could try the Omron Generic EDS file available on this site which works with most devices. Share this post Link to post Share on other sites
