Posted 22 Nov 2022 I have several machines that use the RJ71EIP91 module. I have not had any issues until now. I do not have the original apa file. I upload the configuration and try to restore it from the configuration.apa file, it does not show everything that is connected to the card or programmed in the PLC. when I verify this it says that the configuration is a mismatch. I have several of these scattered throughout the factory and I don't have this problem anywhere else. Is there a solution to this problem? Share this post Link to post Share on other sites
Posted 22 Nov 2022 I forgot to mention that there are 6 connections that are programmed into the PLC for this card. Two of which are Fanuc robots and four are stepping motor controllers. When I upload it only shows the robots and only one stepping motor controller. I tried manually adding the three remaining connections to the configuration but it still does not work "mismatch". I can ping all the addresses, I wonder if something else was programmed in and later disabled. Without the original apa file I don't know how to figure this out. Share this post Link to post Share on other sites
