Robafe
Serial Port issue
Sorry its long !!
I am recieving text from a GSM modem for text msg Send and receive (SMS)
works ok but would be better if I could make use of the start code and end code.
This way I could cut down on all the crap that is received when a text arrives.
I get this
CMTI: "SM",0
I have it stored into D80 and I have that trigger a TXD that sends
AT+CMGRD=0 and that tells the GSM to send the msg (The 0 is the current msg in memory)
------ The problem is that there is Carriage  Return and Line Feeds in the received msg ----      AS below
((AT+CMGRD=0
+CMGRD: "REC UNREAD","+19028991212","","22/10/20,16:57:54-16"
 Hello this is the msg
OK))
When the PLC sees the carriage return it stops receiving data. And I have no start code or end code setup. (I am using characters received)
The way around this is to set a high  character count in the RXD (More than the actual msg (More than the msg length)
The main issue with that is I get garbage in as the msg gets bigger. Its unreliable.
I clear the port after each receive and that helps but still get the odd garbage. (Never get garbage when connected to a terminal prg).
Any Ideas????
ps
Even the Start Code is unreliable as it will start receiving a few characters late.
Rob
Couldn't you setup your end code as "))"?
Just one ")" I mean, which would be a value of 29 (hex)
It stops receiving as soon as it sees any CR LF Never gets to the end code (port 2)
Also
Port 1 is setup to receive 14 chars. A phone # and location code
9025552565A001 when I send it over and over it will change on of the #s Like instead of 902 it will show 912
Basically the same issue as I have with port 2
I wired the connector up from an example on this site I will find it and past it here.
I have had a lot of issues with these omrons.
2 CP1L and one will NOT connect to my NB the other connects works ok
Modem  PLC
           2 - 3
           3 - 2
           5 - 9
    (4,6)    (4,5)
    (7,8)     (7,8)
Rob
Edited by Robafe
Is there a wiring diagram for hardware flow control? for the serial ports????
Rob
Rob
