Posted 14 Oct 2022 Hello, I am trying to communicate with a QJ71E71 , via a PC I am using the melsoft protocol via a software called Delphi that i created. As of now i am able to ping the E71 , but when i send data (loop test) it does not send anything back. I have started with a loopback test as it seemed easy enough. i send this according to wireshark. but nothing in return. Is there something i am missing? do i need to have any ladder logic in the PLC to communicate via UDP? Thanks 54001234000000FF03FF0000210010061900000005ABCDE Settings are as follows: Module 1 Network type : ethernet Start IO: 0020 network no, group no , station no : 1 status Online OPERATION SETTING are as follows ASCII Code, Always wait for OPEN, Enable Online Change is true. for Open setting protocol : UDP fixed buffer : send fixed buffer communication : Procedure Exist Pairing : disable Confirmation : no confirm Host station port 4001 then my IP and Port is 1398 not sure if correct port? or if that matters? Share this post Link to post Share on other sites
Posted 14 Oct 2022 Hello, There is configuration that is required. See my first response in this thread: https://forums.mrplc.com/index.php?/topic/41731-fx3ge-communication-with-kepserverex-via-udp-protocol/#comment-190141 It might help. Share this post Link to post Share on other sites
Posted 14 Oct 2022 (edited) Hello Mark, i tried that and same thing, it will send but never receives. The count for sending keeps going up but nothing is returned, when i try to do the bits it will show that its keeps reconnecting and then timeing out , then reconnecting...ect.. Also if i have UDP setting , i cant select anything in the open system field. its just blank Edited 14 Oct 2022 by Glen7829 Share this post Link to post Share on other sites
Posted 14 Oct 2022 (edited) Zip up the GXWorks project and post it here or PM me Edited 14 Oct 2022 by Mark- Share this post Link to post Share on other sites
Posted 14 Oct 2022 I looked at the settings for an FX project. Here is a screen capture. Share this post Link to post Share on other sites
Posted 14 Oct 2022 I tried this but same issue. nothing returned looking threw wireshark Share this post Link to post Share on other sites
Posted 14 Oct 2022 i get nothing returned with either. no error no gibberish nothing. I can look in the Dianostic tool and it shows it received x data and it says it send 0 data. so i know its making it to it... Share this post Link to post Share on other sites
Posted 14 Oct 2022 (edited) forgot to unplug , but now the peakhmi is sending and receiving so that's good start! Program i made is now also sending and receiving. not exactly receiving what i want.. but ill take it lol. i guess changeing the port to 5001 and 5002? Edited 14 Oct 2022 by Glen7829 Share this post Link to post Share on other sites
Posted 14 Oct 2022 (edited) Very good. I suspect the port number was OK, you can test it. Setting up the send and receive fixed buffer. Edited 14 Oct 2022 by Mark- Share this post Link to post Share on other sites
Posted 15 Oct 2022 i removed the receive buffer (according to the manual its not needed, you only need the send) and same thing it will now send back but its error data.. which is good that its talking now. Thanks for the help! Glen Share this post Link to post Share on other sites
