Posted 8 Oct 2022 I have a CP1L-EM and the serial ports - both of them have an issue with the port ready flag will not turn on. Power cycle still no port ready flag In settings both ports are set up as 15200 8N1 CR/LF Verified and power cycled and still no port ready flag. Is there someplace in the PLC where the ports can be disabled? Rob Share this post Link to post Share on other sites
Posted 8 Oct 2022 I have seen this once before although my memory on the cause is a bit cloudy. I believe I toggled A526.01 and that got it back in action. Have you poked around the A bits and words? Lots of information to look over. I think I locked up the port when an incorrect Baud/parity etc. was received and it wouldn't clear. Try removing the cable from the port and then reset it. If it becomes ready and then drops off again when you plug in the cable then it is likely a baud rate/parity etc. mismatch. Its a bit silly that it locks it up. Your issue may be totally different that was just my experience. Share this post Link to post Share on other sites
Posted 9 Oct 2022 I was poking around in the A bits killer is I couldn’t get the MB connected to my plc Cp1l em 20 so I load my pre into my Cp1l em 30 and the MB connected right up then I noticed the serial ports not working. I swear someone doesn’t want me to succeed with this project Sending and receiving SMS msg to from a Waveshare 4G DTU Thanks a lot for the reply photovoltaic … Share this post Link to post Share on other sites
Posted 11 Oct 2022 I have it working now- phew....... A very dumb and embarrassing mistake on my part. I really thank you for your help. Rob Share this post Link to post Share on other sites
Posted 11 Oct 2022 50 minutes ago, Robafe said: I have it working now- phew....... A very dumb and embarrassing mistake on my part. I really thank you for your help. Rob We've all made those - care to share what it was? I'm sure you weren't the first and won't be the last. Share this post Link to post Share on other sites
Posted 11 Oct 2022 You asked for it Remember DUMB First off, I still cant get the CP1L-EM 20 to connect to the NB The CP1L-EM 30 Connected right away And the DUMB part was I didnt check the Com Port switches on the EM 30 I was so happy the NB worked I totally forgot...... Doh Rob Share this post Link to post Share on other sites
Posted 11 Oct 2022 2 hours ago, Robafe said: You asked for it Remember DUMB First off, I still cant get the CP1L-EM 20 to connect to the NB The CP1L-EM 30 Connected right away And the DUMB part was I didnt check the Com Port switches on the EM 30 I was so happy the NB worked I totally forgot...... Doh Rob Oddly enough I was thinking about the reason you might have been referring to last night when I should have been sleeping - this is exactly what came to mind. I bet you won't miss that again! Don't feel bad, I have had probably 6 calls where people lost comms because of this. One customer sent me his PLC because the Serial port was "faulty". Share this post Link to post Share on other sites
