mmmmgggg
Get the output of FileWriteVar in human format
9 posts in this topic
Hello,
I am using FileWriteVar function to save in a file the value of an array. I have read in the documentation that this data is saved in binary format.
Can I see this data saved in the file in a human format? It doesn't matter using Wordpad, Excel, Internet online converter...
What's the decodification type of this file? For example, when you import a file in Excel it asks you if it is Unicode (UTF-8), European, Arabian...
Thank you for your help!
Hi!
First of all, thank you for your response.
I have tried converting my binary file extracted from Sysmac in the webpage https://www.rapidtables.com/convert/number/binary-to-ascii.html (the binary file extracted with the function FileWriteVar) but I don't receive the response that I wanted.
The array that I want to save is a recipe, so I don't want to start concatening the elements and converting to string and things like this, because then, I want to use the same file with FileReadVar function to return to the past values in Sysmac.
Convert the numbers to strings first if you want them human-readable
Edited by photovoltaic
Not enough coffee
Just noticed your comment about strings... I don't see a way around it. You can covert from a string just as easily when properly parsed
Hello! Thank you for your answer!
I was saying that I didn't want to convert to string directly from Sysmac because my variable is not a simple real; the variable that I'm writing in a file is a structute created  by me composed by strings, array of reals, array of booleans, booleans... But I understand that I can't open the output file of FileWriteVar in a human readable format unless I don't convert each element to a string.
Consider using something like python's "struct" class to read your binary file and print the decoded results.  It can handle mixed structure types.
Hi @pturmel
I see very interesting what are talking about python struct.
I have tried with some code samples found on Internet, but I don't get the result that I want.
For example with this code sample:
import struct
f = open(r"C:\Users\user\Desktop\RECIPE_001.dat", 'rb')
data = f.read()
data_unpack = struct.unpack('>f?7s', data)
print("data_unpack: ", data_unpack)
f.close()
I get the next error:
struct.error: unpack requires a buffer of 12 bytes
Do you know what I need to write instead of '>f?7s' regarding to the file extracted from Sysmac?
Thank you!
