Posted 28 Sep 2022 when doing program, sometime really need a long period timer, I used to use RTO retentive timer, that can make 69 minute time delay. but recently I got problem. the production runs 24x5 hours, I have to keep one of my program function to monitor the equipment fault, I could not get the plc time by using GSV. the system time doesn't work. (all the other production lines, the system time work well, only this line 1769-L30ER 5330ER) By calculation, one day is 24x3600 seconds, six day is 144x3600 second, so I use CTU to count the every second, and use the CTU.ACC as relative time record. If the production line runs five days with no stopping, the counter will count to 120x3600 second, it's long enough to keep the monitor on. once the line stops, reset the counter to zero. waits for next starting up. S. Green Share this post Link to post Share on other sites
Posted 28 Sep 2022 I am not following your problem. The Preset of an RTO in RSlogix 5000 Version 20 , the last supported version for 1769-L30ER is a DINT. As a DINT it can go out to 2,147,483.647 milliseconds or 2,147,483 seconds or 35,791 minutes or 596 hours or 24 days. This is well beyond the week you need. Have you tried the following code for your system time - "GSV WallClockTime ? DateTime LocalDateTime[0] " with LocalDateTime as an array of 7 DINT. Both appear to work 1 person likes this Share this post Link to post Share on other sites
Posted 29 Sep 2022 For accumulating timers like that, I generally use a high priority periodic task with its interval set appropriately. Put an ADD instruction behind whatever conditions you're checking for. It'll accumulate a LONG time with a DINT tag. If I want to track how long the machine was in different modes, I just put an XIC with the bit for that mode in front of the ADD instruction. You can log the time or do whatever you need to with it at the end of the day. If the same code in other PLCs works to get the system time but not this one...but this one works fine otherwise...I'm not sure what to say. What PLCs do the other machines have? When you go online with the processor and go to the Date/Time tab of the Controller Properties, are the date and time correct? What goes wrong when you try the GSV instruction? Do you just get bad data back or does the instruction fail? Share this post Link to post Share on other sites
