paulcoverley@sky.com
serial input string
3 posts in this topic
Hi
I'm quite new to plc but very new to mitsubishi.
I have an input string eg G+002.7 which represents a weight.
I wish to take in the input string then move/convert to int omitting first char,
On other plc's i have been able to use a modifier like d200[2] then the no of chars.
How do i achieve this in gx works3
Any feedback gratefully recieved
Paul
will this string always start with "G" ?  If so, Change your HMI input to be Float input and just add the G as a prefix visually
If not, then a block move (BMOV) starting at the second register of your string address would drop the first characters.
Edited by WattUp
if not answer.
Hi , thanks for your reply - to provide a bit more info please see below images of prog and registers.
From the results recd I'm only interested in D201-D203, however i will need to pick up to + sign ie the 2nd byte of d200.
I want to use the +2307.4 in calculation as a signed integer.
Any further feed back greatly appreciated
Many thanks
Paul
