Posted 22 Apr 2022 Hi I'm using the omron function block modbus tcp server, I have this error of 220F. I'm think got anyway by using program I can reset the socket I use for the modbus tcp or reset the ethernet port. Share this post Link to post Share on other sites
Posted 25 May 2022 Have you done the programme ? since I will be using to the Modbus TCP Server for CP2E Share this post Link to post Share on other sites
Posted 25 May 2022 https://www.support-omron.fr/details/bloc_fonction.php?id=2020-04-16%20-%2011-04-35%20-%201116722129 Share this post Link to post Share on other sites
Posted 25 May 2022 I'm using Modbus TCP Server for CP2E to send the data from PLC to network server. the IP address set is 10.39.15.200. When I go online and download, the function block cannot established since there is no response from the (BOOL) established. But there is one time suddenly the FB can be connected & established and then after repeat again it is not connected until now. After doing a cross check in the function block, I found that it is due to the TCP Status connection but I have no idea how to solve this issue. Need an opinion and help, thank you. Share this post Link to post Share on other sites
Posted 25 May 2022 For modbus tcp server programme that you shared recently, it just include only IPClient 1, IPClient 2 & IPClient 3. how about the IPClient 4 ? Share this post Link to post Share on other sites
