A.J
Automatic sub
12 posts in this topic
Hello everbody,
I'm olmost programming plc for 2 years now. So i no some of the basic stuff. But now i want to trie somting new for me.
Every minute i wont to lower the output of a valve.
I can't find a way to make this work.
For exampel
Thank for your support.
greetz
Hello A.J,
     There are lots of ways to do this:
  • One approach would be to use a 1min timer.  When the timer completes, lower the valve and start the timer again. (Timers like TON, TOF, OUT_T, etc.)
  • Another approach would be to use PLC's internal system clock (SD214 - depending on PLC) and lower the valve when the value changes.
     Which PLC are you working with and what language are you programming in (ladder, FBD, ST)?
Hello Integrator,
Thank for youre fast respons.
I thought i had put a example pic but that din't upload.
So i just make one sketch whit exel, than it hits me mabye this wil work.
I use a FX5 plc.  I what thinking on do making it whit FBD. but i can ols make it in ladder.
Againe can't i get mij upload on this post.
Edited by A.J
You need to add far more detail.
Analogue? Voltage/current . Many types of valves.
Too vague to answer yet.
There was an issue with attachments not working, the site has been fixed if you try it again.
Crossbow,
thank you for the update.
In the mean while i have a dissolved this problem.
Thank you  for everonys help.
Greetz,
A.J.
Which attachment was it? I might be able to fix it?
It was a pgn file. Named example
you mean *.PNG?
Yes you are right. Me bad.
PNG is supported. must be the issue with attachments not working earlier this month. Its fixed now.
