Posted 25 Dec 2021 Can someone help me how to transfer D memory in gx works 2 but only 8 bit (Mitsubishi D memory is 16 bit cmiiw) ? Share this post Link to post Share on other sites
Posted 25 Dec 2021 Easiest I know is to use the move instruction. MOV K2M0 D0 This moves 2 nibbles (K2=2 nibbles=8 bits) starting at M0 to D0. 1 person likes this Share this post Link to post Share on other sites
Posted 25 Dec 2021 @CangkeMan You should use SMOV or AND data with H0F like this Assume that data in D0 and destination are D10 -| M0 |------[SMOV D0 K2 K2 D10 K2] or use "AND" function -| M0 |------[WAND D0 H0F D10] 2 people like this Share this post Link to post Share on other sites
Posted 27 Dec 2021 do you want to preserve remaining 8-bits in the destination? 1 person likes this Share this post Link to post Share on other sites
Posted 5 Jan 2022 @Wasan I didn't find SMOV instruction, I use Q01UD PLC. So i use serial to communicate with some devices. the device can't accept null data (which is one ASCII Character 8 bits data) in the middle or front in the row data of the device format requested. null data must be behind CR in order to be read by the device. how can i move the data 8 bits forward ? https://drive.google.com/file/d/1SdY9aCKCJx5YcUwinYg31LIsBFEEQX2d/view?usp=sharing Share this post Link to post Share on other sites
Posted 5 Jan 2022 Thanks for the answers guys, case closed. I am using $+ to combine data and it is work for me. Share this post Link to post Share on other sites
