skyfox
Can a integer tag be addressed at bit level?
9 posts in this topic
NX1P2 / SYSMAC Studio (latest version)
Say I have an integer tag named "CMD" Is there a way to use the individual bits of that integer in Logic with Sysmac?
      CMD.00
Sysmac doesn't do bits like other platforms. The easiest with to accomplish this is with CJ Series Memory addressing. Make a bool[16] array and assign the same address and the bits will reflect the contents
1 person likes this
Thank You.
In that case do I still need the integer declaration? Instead, could I just use tag "CMD" with a data type of  "ARRAY[0...15] OF BOOL" with %D0 AT designation directly?
If you don't need to use it as an integer yes. But if this is the case you may as well not bother addressing it with AT at all and just use bits or a BOOL array. Using the address is only for the purpose of bit extraction in this case - like when you receive a status word from a device and need to pick out the bits.
I Was under the impression AT designation was needed for NB Series HMI to exchange data with an NX1P2.
Yes, in this case you can treat it as an integer on the NB and address a BOOL[16] array in the PLC.
I realize I need both the integer and the bit format for what I am wanting to do. Suppose I have the need for this functionality (resolving bits from an integer) just in the NX1P2 without involving the NB HMI. I don't see a way around without using  AT designation and without using CJ-Series memory. Does NB HMI read all CJ-Series tags with a AT designation from Global variables, or just the TAGS that are referenced  within the HMI program?
Thanks again for the help.
Cheers.
Edited by skyfox
Cheers.
There is another way to extract bits in Sysmac using a Union datatype but I find the addresses easier.
The HMI will only read/write tags specified in the HMI application
Great. Thank you.
