Posted 16 Oct 2021 HELLO EVERYONE THERE IS THIS PROJECT WHERE I CHANGED THE OLD SERVO SETUP WITH NEW SERVO DRIVE MRJ4200A-RJ SERIES. OLD SERVO HAS A REVOLUTION OF 15 BITS BUT NEW SERVO HAS 22 BITS RESOLUTION. PROGRAMMING IS SAME BUT MY DISTANCE CALCULATION IS DIFFERENT NOW AND MACHINE DOES NOT GIVE CORRECT DISTANCE. PLEASE HELP ME Share this post Link to post Share on other sites
Posted 16 Oct 2021 hi vipin, you should check the servo setup.With regard to the travel distance, there are two essential parameters - number of pulse per rotation (depends of encoder resolution) - movement amount per rotation (including the gear ration) I would first compare these two settings Share this post Link to post Share on other sites
Posted 17 Oct 2021 THANKS ANDREAS WILL DO CHECK THESE PARAMETERS. Share this post Link to post Share on other sites
