Posted 13 Oct 2021 Hi. I have the CD with SYSMAC Gateway Runtime V1.6 and installed the full CD. I still cannot add a reference to Omron.Compolet in Visual Studio 2019. And the project i am trying to open, complains about OMRON.Compolet is missing. Any idea whats missing to get the OMRON.Compolet to show up in VS.Net 2019? Share this post Link to post Share on other sites
Posted 13 Oct 2021 have not used it but according to Omron, you do not add reference.... after installation of Compolet, you should have the control show up in the ToolBox (at the bottom of the list) and you need to drag it onto your form... the same way you would use timer or button or textbox: https://www.ia.omron.com/data_pdf/cat/cx-compolet_v302-e1_13_5_csm1000258.pdf?id=63 Share this post Link to post Share on other sites
Posted 14 Oct 2021 16 hours ago, panic mode said: have not used it but according to Omron, you do not add reference.... after installation of Compolet, you should have the control show up in the ToolBox (at the bottom of the list) and you need to drag it onto your form... the same way you would use timer or button or textbox: https://www.ia.omron.com/data_pdf/cat/cx-compolet_v302-e1_13_5_csm1000258.pdf?id=63 Hi. I learned later that it was not the CX-Gateway that was supposed to be installed, but the separate CX-Compolet cd, then it worked after installing a ton of software including cx gateway :D Share this post Link to post Share on other sites
