Posted 16 Sep 2021 Please Help me, I want to connect aczet brand weighing machine CG203L to PLC CP1L-M. But several times I tried it didn't work, I've tried repeatedly in the settings section to adjust the baud rate and mode and have tried one by one but to no avail. Can any of your friends help? thank you Share this post Link to post Share on other sites
Posted 15 Jul 2022 Hi, do you know what type of communication this scale uses? I'm no expert but I can try to help you. Share this post Link to post Share on other sites
Posted 15 Jul 2022 On 9/16/2021 at 9:53 PM, Bhakti said: Please Help me, I want to connect aczet brand weighing machine CG203L to PLC CP1L-M. But several times I tried it didn't work, I've tried repeatedly in the settings section to adjust the baud rate and mode and have tried one by one but to no avail. Can any of your friends help? thank you Sharing your program will help. Also a manual for the scale as I can't find anything outlining the communication specs. The port mode should be RS232C and you should be using TXD and RXD instructions. Without a manual that's all I can tell you. Share this post Link to post Share on other sites
