Qasem
RTD - 1746-NR4 color RED or Green
9 posts in this topic
Hi,
I have new RTD module the same specification as the old one however looking to the front face of the RTD a difference can be seen:
The old module is GREEN
The new module is RED
Anyone can tell me what this means?
You're not color blind.
But maybe the people that made them are.
I am not color blind . The new module I bought from the internet and never expected the color
The printed info as follows:
GREEN   RED
SLC 500   SLC 500
RTD / resistance INPUT MODULE   RTD / resistance INPUT MODULE
1746-NR4   1746-NR4
SER B   SER B
FRN 2   FRN 2
RTD TYPE: PLATINUM, COPPER.NICKEL,NICKEL-IRON   RTD TYPE: PLATINUM, COPPER.NICKEL,NICKEL-IRON
RESISTANCE: 150OHM, 500 OHM, 1000 OHM, 3000 OHM   RESISTANCE: 150OHM, 500 OHM, 1000 OHM, 3000 OHM
WIN (21) 1P0GN2X0 Mfg: 0897 FAC. 1P   WIN (21) 1P0YJ9AJ mfg: 1002 FAC. 1P
OPERATING TEMPERATURE CODE T3C   OPERATING TEMPERATURE CODE T3C
CLASS I, GROUPS A, B, C, AND D, DIV.2   CLASS I, GROUPS A, B, C, AND D, DIV.2
As Data would say  "I could be chasing an untamed ornithoid without cause."
Since the GREEN Unit was manufactured in 1997 and the RED was manufactured in 2002 I'd guess that the color changed as a result of what plastic was available and had little to do with the function of the units.
I looked it up real quick because your question made me curious. According to Rockwell's Knowledgebase article QA11393 (Access Level: TechConnect for some unknown reason...), the green one was used for 1746-HSCE, -HSCE2, -IO12, -NR4, -NI8, -NO8I, -NO8V, -NI16I, -NI16V modules while the red one was for 1746-IA16, -OA16, -IM16, -OAP12. The article doesn't go into any other detail about any differences between the terminal blocks.
Page 171 of the user manual actually goes into a little more detail about which RTB to use for which module but, again, doesn't offer any details about the difference between them other than color.
These installation instructions seem to say that the color coding is there to help you avoid accidentally connecting the wrong voltage to the module. It only asserts that you shouldn't mix-and-match when it comes to thermocouple modules.
When replacing the module with a new one, I would loosen the screws that hold the terminal block to the module, leaving the wiring intact. The installation instructions (linked above) explain how to do that.
Thank you for your explanation. I find it useful
