Posted 29 Jul 2021 Hi Can anyone help with some documentation to setup communication of two Omron NJ/NX PLCs via the internet? Thanks Share this post Link to post Share on other sites
Posted 30 Jul 2021 https://www.ewon.biz/products/cosy https://www.tosibox.com/product/lock500/ VPN is by far the easiest method. If you have a PC with Sysmac Studio installed, you can use Teamviewer. I haven't tried this but here is a link from MyOmron. https://www.myomron.com/modules/KB/file_d.php?id=743 Share this post Link to post Share on other sites
Posted 30 Jul 2021 (edited) Hi @IO_Rack We have regularly used the VPN to access PLCs for programming changes but I am confused how I can use the same method to connect to PLCs together? I'm guessing there is away of setting up port forwarding on both routers if I have a static IP at each side? What I am trying to do is basically send alarm data to a second PLC which is approximately 50Kms, and have this warn the operator and slow down the equipment. Thanks Edited 30 Jul 2021 by NootNoot Share this post Link to post Share on other sites
Posted 2 Aug 2021 I have asked the forum moderators to see if they can restore the file from this post: https://forums.mrplc.com/index.php?/topic/28751-plc-plc-via-internet/ This looks like the information you are looking for. Share this post Link to post Share on other sites
Posted 13 Aug 2021 @NootNoot @IO_Rack I have fixed the links in the other thread. Share this post Link to post Share on other sites
