Posted 23 Jun 2021 we have 4 micrologix 1200 plc which i would like to read the data off them IE Amps Temp run time they were set up via a third party to do this but the company is no longer in go i can see the plcs on RSlinx classic lite but wont let me go online as it say processor not supported. i don't want to alter or change the program just get the data will ASComm work or any other software don't want to buy RS logix 500 just to get the data any help would be great Share this post Link to post Share on other sites
Posted 23 Jun 2021 Can you tell us what version of RSLinx Lite? You should be able to right click in Linx and select Data Monitor and see the tag values in the PLC. RSLinx OEM, RSLinx Gateway and Kepware Server would be able to pull the data into Excel for you. Also Ignition, Wonderware and OSISoft PI have drivers to pull data. And I am sure there are others. Share this post Link to post Share on other sites
Posted 23 Jun 2021 (edited) I would normally just buy Kepware (with its AB drivers) and use OPC/UA. Edited 23 Jun 2021 by pturmel Share this post Link to post Share on other sites
Posted 23 Jun 2021 Name Catalog # List price RsLogix 500 Micro Starter 9324-RLM0100ENE $151 The above is not too bad. Might be a little more now. Share this post Link to post Share on other sites
Posted 23 Jun 2021 1 hour ago, BobLfoot said: Can you tell us what version of RSLinx Lite? You should be able to right click in Linx and select Data Monitor and see the tag values in the PLC. RSLinx OEM, RSLinx Gateway and Kepware Server would be able to pull the data into Excel for you. Also Ignition, Wonderware and OSISoft PI have drivers to pull data. And I am sure there are others. hi, thanks for the reply its the latest version from Rockwell, have tried data monitor but returns the note processor not supported thanks 2 hours ago, Heywood said: we have 4 micrologix 1200 plc which i would like to read the data off them IE Amps Temp run time they were set up via a third party to do this but the company is no longer in go i can see the plcs on RSlinx classic lite but wont let me go online as it say processor not supported. i don't want to alter or change the program just get the data will ASComm work or any other software don't want to buy RS logix 500 just to get the data any help would be great Share this post Link to post Share on other sites
Posted 23 Jun 2021 I can't find proof of this on the AB/RA sites yet, but given the age of the 1200 it's support might not be in the latest linx. Try version 2.56 ot 3.90 and see if the problem is the same. Share this post Link to post Share on other sites
