Rodrigo Balsalobre
HELP WITH ETHERNET COMMUNICATION LOGO8 SIEMENS AND KINCO HMI
 Hello!
  I was trying to communicate my siemens logo with an kinco hmi but this error are appearing on the hmi, what am I doing wrong? Im using an ethernet hub!
ETHERNET SETTING ON THE HMI
1.thumb.JPG.f571126076ac07040aa4743403d1
THE PUSH BUTTON THAT ACTIVATES M1
2.thumb.JPG.24d0c1dbd50ffd0ace913e0f03bb
THE LAMP THAT'S REPRESENT "Q4"
3.thumb.JPG.bd45fc84072c33e1617cb5cfc1e7
AND THAT I DON'T KNOW HOW ITS WORKS BUT I JUST PUT ON THE SCREEN TO
4.thumb.JPG.c5207fa2661228db1434f0870e8a
THE PROGRAM ON LOGO SOFTCOMFORT
5.thumb.JPG.ac0fdb76a599e50df07ac090a6f7
I JUST SET THE LOGO AS SLAVE WITH THE HMI IP
6.thumb.JPG.9558bdf4be768d26ffaaee2fdb71
THE LOGO IP
7.thumb.JPG.cc0506265a357d78bfee152deeaf
8.thumb.jpg.b95e0cd50c552b6fd1e53e26f284
AND THE ERROR MESSAGE
9.thumb.jpg.876fdb33675f4e7b5413ab35db8b
Hi,
You must allow LOGO to be accessible
Go to online settings \ Access control settings  and allow data to be accessed by Ethernet.
I am not sure also about your program, but might be also necessary to add on parallel with your output Q1, an network output NQ1( V0.0 for example). Then you will check in HMI the status of  network output,  respectively status of V0.0
Try those things and let us know your results.
16 hours ago, dekor said:
Hi,
I think it's already  allowed, can you help me with that?
1.thumb.JPG.e506fc55109bf1e5517cfedd0748
2.thumb.JPG.51bdf6395b300a10828cdd44489d
And about the program, I just make it equal like this video: https://www.youtube.com/watch?v=-OhAgn4TGBw&t=65s
The guy who made this video takes a while to do it correctly because he make a mistake, but the final result is equals than mine
I can to this communication using the hmi as a slave, but with that, its more hard to do what I want, like on the video that I sent, the hmi uses the i/o from plc, using the plc as a master its like that:
The ethernet connection on hmi software
1.thumb.JPG.0a8ed0114344b27219f99595781f
The type of adress and his number:
2.thumb.JPG.d536b13937c583bf6484ba1164f3
How you need to write on plc:
3.JPG.328231ba5d47665c8ec311314cceb01c.J
  And theres an error with this program, for some reason he stopped to work like yesterday, but I will fix it
  Btw, on this method, it's like i said, it will be more hard to do what i need after this simple logic
 As you can see, theres no error with this method
5.thumb.jpeg.a2850f02bfa271c1d23797e40da
Edited by Rodrigo Balsalobre
just fixed the problem that i said before, but its using the other method that i tought, It will be nice if uses the hmi as a master like the first method with that error
