Graemek25
File Copy for NX/NJ
Hello,
I have used RSlogix5K for years and I am now creating NX/NJ PLC program.  Is there a similar command to 'COP', which can copy ALL the data from a structured variable to either another equivalent structured variable or to a data array of some kind - e.g. a byte array?  I thought the MemCopy command might do this but I believe it only handles arrays, not structured vars.
Many Thanks
Graeme
MOVE will copy an entire structure. Just specify the parent tag.
If you want to put the structure in a byte array use ToAryByte
2 people like this
Since you mentioned Logix, I'll just add that Omron doesn't automatically convert anything. You must be mindful of your apples and oranges. :-)
They do have a lot of conversion instructions.
The MOVE instruction now does indeed convert data types (only certain combinations where you don't lose resolution however).
MoveConvert.jpg.5b02284f7215db50c94c4f2d
3 people like this
Nice! Thanks for the update!
It's also nice you were able to post a picture!
