Posted 3 Jun 2021 Hello, I have used RSlogix5K for years and I am now creating NX/NJ PLC program. Is there a similar command to 'COP', which can copy ALL the data from a structured variable to either another equivalent structured variable or to a data array of some kind - e.g. a byte array? I thought the MemCopy command might do this but I believe it only handles arrays, not structured vars. Many Thanks Graeme Share this post Link to post Share on other sites
Posted 4 Jun 2021 MOVE will copy an entire structure. Just specify the parent tag. If you want to put the structure in a byte array use ToAryByte 1 person likes this Share this post Link to post Share on other sites
Posted 4 Jun 2021 Since you mentioned Logix, I'll just add that Omron doesn't automatically convert anything. You must be mindful of your apples and oranges. They do have a lot of conversion instructions. Share this post Link to post Share on other sites
Posted 9 Jun 2021 The MOVE instruction now does indeed convert data types (only certain combinations where you don't lose resolution however). 2 people like this Share this post Link to post Share on other sites
Posted 10 Jun 2021 15 hours ago, Michael Walsh said: The MOVE instruction now does indeed convert data types (only certain combinations where you don't lose resolution however). Nice! Thanks for the update! It's also nice you were able to post a picture! Share this post Link to post Share on other sites
