Posted 24 May 2021 Has anyone successfully used a 1783-NATR for Modbus TCP communication between a ProSoft MNET card (in the ControlLogix rack) and a Modicon Quantum? ProSoft MNET: 10.x.y.z Modicon Quantum: 192.168.1.x There is one (1) ProSoft MNET and four (4) Modicon Quantum's. NOTE: I know there are other devices that support this behavior...the NATR is the suggested standard hardware. We are getting various responses from distribution and support. ...I was hoping someone in the community could confirm. Thanks for your time! Share this post Link to post Share on other sites
Posted 24 May 2021 Port 502 will not be open on a 1783-NATR by default, you'll need to enter a rule into the NATR for the Modbus-TCP to go through. This much I know.. I've seen them work, but was not the engineer/tech who set it up. 1 person likes this Share this post Link to post Share on other sites
Posted 24 May 2021 Bob, I think you meant 502, that is the Modbus default port. Share this post Link to post Share on other sites
Posted 24 May 2021 44 minutes ago, Ken Moore said: Bob, I think you meant 502, that is the Modbus default port. YEs - Ken I "fat fingered" an extra 0 in there. Share this post Link to post Share on other sites
Posted 25 May 2021 Thanks for the replies... I have a demo unit on the way...we'll test and post the results. Share this post Link to post Share on other sites
Posted 26 May 2021 (edited) NATR received. We've run it across our MB Simulator and everything is working... MB Sim (@ 192.168.1.131/24 GW 192.168.1.1) < -- [Modbus TCP on Port 502] -- > KepWare OPC (@ 10.0.11.123/24 GW 10.0.11.1) NATR Config: Public IP: 10.0.11.139/24 GW 10.0.11.1 Private IP: 192.168.1.1/24 GW <blank> Network Address Translation: Public IP (Translated): 10.0.11.131 Private IP (Destination): 192.168.1.131 NOTE: Private IP (Destination) should be actual IP addresses (physical devices) in the NAT'd area with each device Gateway set to the NATR Config Private IP (192.168.1.1). Custom Rule: tcp/udp 502 We'll get real hardware to validate against over the next few days... Edited 26 May 2021 by Jim Hortenberry Share this post Link to post Share on other sites
