Posted 18 May 2021 Hello guys! Im using RS Logix 5000. Can someone explain me what is the difference between when a servo is shutdown or disabled ? I read the help but it says the same. I can assume it like when its shutdown, there is inside some circuit which is not allow the 3 phase for the drive. Disabled is that when it have the 3 phase but nothing can happen ? Is there any difference with the break ? Like when its shutdown it can rotate until its slow down by itself or the break will be active ? I tried to uplod a pic but it was not succesful. When you open a servo axis properties and you choose the Fault actions tab. You can find there these settings. Thanks a lot. Share this post Link to post Share on other sites
